One word of advise. Don't run spacers and the plenum unless you've got a fair amount of vacuum tube lying around. My PCV tube and my tube that runs from the intake tube to the rear valve cover had to be modified to reach because the plenum sits up so much higher with the spacers.
I ran into only one problem. One of the holes for my EGR valve bolts was jacked up and had to be chased with a tap. It would have been much easier to do if I had the plenum off the car, but when I discovered it, it was all bolted in.
Overall, I'm a little concerned about the loose ends like the EVAP hanging and the pcv tube being barely long enough to fit into the rubber connector on the PCV Valve. I guess I could epoxy the connector to the tube so that it can't come loose.
This mod is definitely awesome though. I had the battery disconnected to splice the MAP so the car feels a little clumsy, but the torque was amazing. I floored it from 20 and it seemed like she was fighting not to lose traction.
