I'm inquiring about useing Comp cams roller rockers on my 3.1 gen 2 engine. I saw them on 60 degree store. I was told they can be used in place of stock rockers but pushrod guide plates will interfere but With a little grinding this will be sufficient?
If useing a aftermarket cam with higher lift, in theory base circle becomes smaller, so this must be compensated by useing longer pushrods. Would I just take the difference from stock vs aftermaket basecircle and add it to the length of pushrod. valve cover clearance?
Do I have to add the preload .030-.040 to length to pushrod length also?
Is there anything else that I'm overlooking, Are the stock rocker arm studs adequate with the comp cams rockers? I beleve their a 10 by1.0mm
Is there a tool that they sell adjustable pushrod, to give you a measurement so you can use it as a reference for a custom pushrod? Currently I'm useing the stock pushrods, not sure if I need them for the new cam, just tring to be prepared.
In theory just want to keep the same rocker arm geometry, I'm a vw mechanic, never really got into the performance aspect, so I'm looking for someone who has more knowledge in this area than myself.
Any imput on a blower cam 3.1 with m62 blower currently crane cam 2030 423 in 423ex @1.5 stock rockers264 in 274 ex. 109 lobe seperation. also useing reccomended valve springs etc. Like the cam but would like more midrange and top end if possible.
Don't want to be too agressive with cam meaning too much overlap or duration, don't want to blow it all back the exhaust. had a few thoughts duration 268 in 276 ex . lift 450 in @1.5 . 471ex @1.5 lobe seperation 112
centerline in 108 ex 116 figured a little more lift and duration on exhaust side due to stock exhaust manifold, but didn't want to go too high. A penny for your thoughts, thanks for your time and knowledge
