When do you think i will be able to get a FPR for my 3400 from your 60degreeV6 Store
FPR Back in stock(When)
If its going to take them a while, I think PFYC still sells the caspers adjustable unit... i could be wrong though.
Originally posted by 3400-95-Modified View PostIf its going to take them a while, I think PFYC still sells the caspers adjustable unit... i could be wrong though.
your only choice is the one here or make it yourself. or if theres another one out there i dont know of.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
This Adjustable Fuel Pressure Regulator allows you to adjust the base fuel pressure on your 2.4L or 3.4L engine. Simple installation. The fuel pressure adjustment range is from 42 to 48 psi. Factory fuel pressure is 40 psi. Higher fuel pressure increases fuel flow on the top end.
Select from regulator only or a complete kit, which includes the regulator plus the following items:
Stainless Steel Hose
Fuel Line T Tap
Fuel Pressure Gauge
Funny it says up to 48psi... If thats the caspers unit, mine is at 55 with no vac on it, so its higher than rated.
Originally posted by 3400-95-Modified View Post$139.99 on PFYC.com under Pontiac Grand Am
dont even have it listed on there site
99 Grand Am GT
