For reference I'm doing headers from a GA in my L-body
The Boringness....
The hotness
Only fitting them, not done yet...
Sitting on the table
It took me all night to get the manifolds out so all I did so far was test fit the front and see if there were any clearance problems. Only one I found was the dipstick needs to be tweaked to fit past the flange. Coolant heater core pipe should clear if properly attached to throttle body with bracket, so I need to replace mine, or just bend it.
Still need to pull my downpipe out and then test fit the rear and see how much needs to be notched out to allow the header to bend down and clear the firewall... I'm hoping it wont be too much, and from the TOG header fit pics I saw it doesn't look like it was much that needed to be removed.
So far, One broken manifold stud on the front... I really dont care because once fitted it only needs to last like 2 weeks before the whole motor is coming out.
So what do you guys think I should see from this upgrade? 10? 20?
The Boringness....
The hotness
