I have recently slightly modified a 3.1 to race on a half mile dirt track circuit.
Running in a manual 92 Cav.
Put a new cam (420-443 lift cam)new lifters, timing chain.Also put 1.6 roller rocker arm a 1.6 ratio from comp cams. Also port match all the runners from the UIM, to LIM ,heads and exhaust manifold. Put 3400 exhaust manifolds and 2.5 inch pipe. Also put aluminium damper pulley and a fidanza aluminium flywheel. Done a little polishing in the TB. Also put back the stock chip in the ECM since everybody is telling me that my JET and Hyperchip is worth nothing.
The car is pulling harder from the corner but still have the same endpoint at 5300rpm. What have i done wrong??? I knew that the gen2 stuff was flow limited but all the porting done bring nothing to the top end!!
thanks..
thanks..
