s10 2.8 cheap power
  • s10 2.8 cheap power
    i have a 89 s10 with 2.8 5 speed. looking to make a little more power. i can't aford a 3.4L so i have to use the stock 2.8. i am going to put a 4.3 throttle body on it. i am going to make some headers. underdrive pulleys. efan off of a sbc camaro. a chip not sure what kind? i am looking for 1.6 rockers does'nt have to be roller rockers. this is a very buget build. where can i find 1.6 rockers. i was told at a parts store i could get them for a ford. does this sound right. it didnt to me. please help
    No Ford rockers are completly wrong. Comp cams sells stamped 1.6 ratio roller tip rockers that are very affordable.
      Not that I've verified this, but isn't the '94 and '95 stamped steel rockers on the 3100 1.6?
        hey raven i thought you where here. iam dragsdaily on s10forum. iam going to find out if the 94-95 have those rockers.
          Yea they do have them. Any 3100 without the roller fulcrum rockers uses 1.6 ratio stamped rockers. But many on this forum are going to tell you that OEM ratios are not very exact. Plus you lose the roller tip Comp offers. Also consider the fact stamped rockers do wear out over a peroid of time. So considering the price and the fact you dont have to hunt for a donor engine the Comp rockers are really apealing.
            You're on the right track
            The larger TB and headers is definitely going to help. Porting and 1.6 rockers will help. Porting can be done cheaply, but read up on it because you can hurt as much as help if you get it wrong.
            Headers are a major thing. On the v6 you want equal length(34-36"), 1.5" primaries into a pretty large collector, then a resonator. After that you can put on a 2.5" system and you'll be ahead at least 15 hp.
            Good luck on it.
            Arn Brown
