fired up and ran this morning for the first time... Open Headers ![smile](https://www.60degreev6.com/vb5/core/images/smilies/smile.png)
Here are all the specs...
2004 LX9 3500
678 miles on bottom end
Ported 3500 Plenum
TCE 65mm TB
TCE 65mm TB adapter
Full race ported & polished heads
Mirror polished combustion chambers
Port matched and polished LIM, 800 grit polished intake tracks.
Deburred and smoothed injector holes
.045" Compressed headgaskets, 10.5:1 Compression
Custom ground cam
.539/.549, 288/293 advertised duration
Comp Cams 26915 LS6 Springs
Comp Cams .015 copper shims
Comp hardened steel LS6 retainers
Comp hardened steel LS6 7 degree locks
'91 2.2L exhaust seals
Stock forged steel crank
Stock forged-Powdered steel rods
Stock pistons
FFP Underdrive pully
TCE External crank trigger
Polished 3400 fuel rail
#36 GMC Typhoon Injectors
350 TPI fuel pump
2002 3400 FPR (55 PSI)
1 5/8" longtube headers, 32" length Over the tranny
Single 3" Exhaust, with Hooker Aerochamber muffler
180F Thermostat
Heated o2 sensor
Custom coolant lines
TB Heater bypassed
Heater core bypassed
Coolant fan override switch
All A/C components removed
Cruse Controll removed
Poly mounts( Front and tranny)
Solid mounts (rear)
Transmition
Stage 3 clutch from EZ-Clutch
OEM flywheel
'91 HM282 (Muncie) Bellhousing
'93 3XTX W41 Muncie tranny
Team GREEN 900LB LSD Insert
Gearing:
1st 3.50
2nd 2.05
3rd 1.38
4th 1.03
5th 0.81
Axle 3.94
2004 LX9 3500
Ported 3500 Plenum
TCE 65mm TB
TCE 65mm TB adapter
Custom ground cam
Stock pistons
350 TPI fuel pump
180F Thermostat
Heated o2 sensor
TB Heater bypassed
Solid mounts (rear)
Transmition
OEM flywheel
Gearing:
1st 3.50
2nd 2.05
3rd 1.38
4th 1.03
5th 0.81
Axle 3.94
