Need 96 3100 Roller Lifters
  • Need 96 3100 Roller Lifters
    Does anyone have some new roller lifters for my 3100, im swapping to a 3400 intake and i was going to change my lifters along with it because they tick when i first start the car and they are going bad. if i put lucas oil treatment in when i change the oil the ticking is very loud and the car runs like crap. if you rev it up and build oil pressure then it stops for about 10 seconds and starts again. but as long a i have the lucas oil treatment they only tick for a little bit. so i just want to change em when i do the manifolds.
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
