How did you rig yours? I would put a breather on there... if I had one that fit in there :P
The transmission bracket, I just enlonged the holes on the transmission mount. I got the 3 bolts into the transmission in, and the top 2 bolts into the block, however the bottom bolt is no where near going into the oil pan. It basically is pressing against the oil pan so if I wanted to weld something up for it to bolt on, I would have had to bend up the bracket. So I just left the bottom oil pan bolt out... I hope it will be OK!
I didn't have to bend the throttle bracket too much... but may be it bent more than I thought so I will check it out when I get home (working late
![Sad](https://www.60degreev6.com/vb5/core/images/smilies/icon_sad.gif)
