LS1 seats from GM. I orderd 5 sets a while back so that I could put them on the store but they still aren't here. Its going on 3 weeks You will also need seals, but that depends on the year of your heads.
Hmm , if you dont get the ls shims, hmm you could do a costume, like I did , hmm I took the shim out out of a s10 pickup and cut the valve seal of it because the seal is smaller.
I did that because I couldnt get the ls shims here at the gm dealer.
So I will use the shims from a LS1 Engine right? But what vehical has these? I know I know the Fbodys but what years. I am not sure. 99-02 I am thinking. Is anyone willing to provide a GM part number so that I can check my local GM dealer.
I dont know what this means but "ASS HATS" is funny
if you tell the dealer you are a parts reseller, they should cut you a discount.
When I was buying dealer stuff, I just told them I worked for meineke or quicklube or whatever, and told them the location and left my number to call instead of calling the place
