Hey all. Well I just got done tearing apart my 3400 b/c of a major failure. The block, the crank, pistons, and rods are all good. The Cam is broken in half, I had a bent rod, and warped heads. Now I have been talking to someone, that said you can swap the 3800 heads on to the 3400 to make some more power. Which heads are these the cast iron head from the early gen or the late model aluminum heads. If anyone could get me part numbers that would be cool. Also I haven't looked at cams but I figured I would put a hotter cam then stock in, but hopefully I will not have burn a new eeprom for it. If anyone has p/n of cams that worked with the computer or cams that required just some tuning rather then a whole new eprom that would be great.
Thanks in advance.
Jess
Thanks in advance.
Jess
