91 beretta
  • 91 beretta
    I was wondering what would give me the best peformance for my money beside boost because I dont have that kinda money I am getting a 91 beretta GT with a 3.1 should it have close to the power of my 96 lumina which in now locked up I know that the lumina had 160 hp not sure what the beretta has I think it is 140 but not for sure what could I do for more HP could I put my heads from the 96 on it or are they not any better I also thout about a 3400 intake will I have a problem puting the OB2 stuff on a OB1 car is there any sensors that are diffirent someone told me that the 96 had a better camshaft is this true could I swap the cam and liffters any help would be great
    this should give you a few ideas.
    those are old pics of the motor, new one is going together as we speak
      sweet car mine is a red Gt only thing I dont like is that it is a auto
        swapping it to a manual is easy. finding the donor car will be the hardest thing.
          I am saving up money to do mods will a 5 speed from a 2.2 bolt up to a 3.1 or are they Different. also will a cavalier work as a donner car.
            i believe the transmission will bolt up from a 2.2 but i wouldnt use it. its an isuzu version and not as strong as the getrag 282. a 90-94 cav will work as a donor car as well.
              Thanks that helps a lot now I know what to look for
                you'll have to check that HP rating again. pretty sure in 91 the 3.1 didn't have 140 HP.
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
                  it did
                    hey i have a set of summit high output coils for a 3.1 and i have a jet stage 2 chip, and a custom burnt chip if yer interested.
                    1996 Beretta
                    3100 SFI TURBO
                    T28 60 Trim Turbo at 9psi, Stage 1 turbo cam mms, lifter upgrade springs mms, P&P heads, ls6 Valve Springs, Ported exhaust manifolds, Hyperuetectic pistons SP, 3.29 trani, MSD 8.5 wires, open exhaust, Pulstar plugs, 3400 intake manifolds, ported TB, 36 lb/hr injectors, RCI Fuel cell, Walbro 255 pump, A/C Bypass, and much more.
                    13.1 @ 103 mph best in the 1/4 mile
                      Sure did. But between my '90 5spd GP and my '91 a4 GP, I've learned that the 140hp rating is very decieving. *cough* eats 3800's and BMW's *cough*
                      '93 Sunbird. 5spd, 3.1, it's fast. Oh, and 240k miles has proven lethal against Turbo Talons
                      I'm lurking occasionaly. It's tough because I'm usually too busy with the Army or my 5.0 Mustang. Which is for sale.
                      camaromanmatt@yahoo.com
                        It did...
                        BERETTA
                        Trim: GT
                        Class: Economy
                        Body Style: Coupe
                        Engine Type: 6 cyl 3.1 L (140hp/185tq)
                        Transmission: 5-Speed
                          ok it has 140 hp but what can I do to get around 165 hp
                            Man dont even worry about the numbers. They are quick stock. But here's what it takes for a 152k mile Grand Prix (remember, beretta are lighter..) to beat a BMW 323i and a 2001 Grand Prix 3800 (220hp).
                            -FULL flowmaster exhaust (not necessarily headers.. stock are good), hi-flow cat (i dont have one, but it would be a great mod!)
                            -SeaFoam your car.
                            -New plugs/wires.
                            -Custom cold-air intake. Keep the temp sensors and PCV.
                            and If ya wanna go crazy,
                            -a chip from this site (in the 60*v6 store)
                            -rocker arms from the 60*v6 store
                            -shift kit
                            -do a top-end 3100 swap (worth a LOT of power)
                            -do some custom head work
                            -cam it
                            -Boost it (prefferably a turbo. This route could cost some change though)
                            Do you really need more??
                              ummm, sea foam? yeah... you want 165 or more....do what i did. can't verify my numbers, but i'm sure i'm close to 170hp and 210tq.
                              Andy
