i ahve a chip both jet and 60*v6 forsale if u want ether of them, also coils, as mentioned earlier. for the 60* chip (6500rpm rev limiter, and no speed limiter)
1996 Beretta 3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mile
IIRC for a 3100 is the gasket you'd use. You'll need custom length pushrods but its been discussed and measured many a time before.
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
hey them coils are they accel by any chance and are they the GM DEI Coils that work on pretty much all GM DEI ne ways will they should work for the Lq1 right? if so and he doesnt want them for his 3.1 how much will u let the 3 go for?
1997 Chevrolet Camaro 30th Anniversary 5Speed.
3800 V6 (i know its not a 60degree)
stock for now
1993 Special Edtion/GTP
3.4 DOHC V6 LQ1 SOLD!
CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
yeah you can do a 3100 top end. The best ones are 2000+ because they use the same heads and intakes as the 3400. And actually in 2000+ the 3100/3400 upper intake is a little better too.
The 94-99 3100 is called "small port" since it has smaller intake manifolds, and it also has a smaller intake valve. The 94-95 3100's also don't have roller fulcrum rockers.
you'll have to get different coolant hoses, power steering pump, 3x00 timing cover....here's everything you'll need to know: http://www.domesticcrew.com/660/ click the bubble on the left side of the screen that says "hybrid".
