I have access to a few injectors from a supercharged cobalt for pretty cheap. They're 32lbs/hr and was wondering if anyone would know if they'd fit Gen3 manifolds/fuel rails?
Cobalt SS injectors
Originally posted by Azrael View PostI have access to a few injectors from a supercharged cobalt for pretty cheap. They're 32lbs/hr and was wondering if anyone would know if they'd fit Gen3 manifolds/fuel rails?
got any pics?
i have a set of Multech 1 #24's that i'd be willing to trade or Multech 2 #22's if that's what your harness is for.
I'm going supercharged later in the year so #24 won't be enough. I don't like the idea of tuning with an RRFPR thrown into the mix so I have to look in the #30-40 range. When I say local, what I meant was the next nearest city so I don't have direct access to them to be able to take pics.1995 Grand Am SE
they "SHOULD" fit physically
however, you should check the height of them installed and if they are sitting in the manifold properly. i helped my friend change his 00+ 2.4L injectors to stock ion redline (supercharged 2.0L) injectors and we had to clearance the rail a bit, to allow the fuel rail to move down a bit (1/4" if that) becase of the shorter injectors.
then i grabbed his 2.4L injectorsgot zap-straps?
89 Z24
13.886 @ 96.16 mph
street trim - slicks
Originally posted by Azrael View PostI'm going supercharged later in the year so #24 won't be enough. I don't like the idea of tuning with an RRFPR thrown into the mix so I have to look in the #30-40 range. When I say local, what I meant was the next nearest city so I don't have direct access to them to be able to take pics.
Originally posted by Superdave View PostL67 injectors are what most people go with when boosting these engines, they are #36 and fit perfect.
Originally posted by blackbombshell95 View PostHow do they fit with the 3x00 fuel rails?
Originally posted by 3400-95-Modified View PostI would assume Perfect since thats what he said...
The L67 injectors were also on my list and I'll probably go with them since they'd just slip right in and are also in big supply. I was just curious if anyone knew if the 2.0SC ones would work as well. I guess GM used shorter injectors in a lot of their new engines then.1995 Grand Am SE
Originally posted by 1988GTU View PostI wonder how those ^ will react with OBD1 (not 1.5) and boost?
Originally posted by Superdave View Postyou'll have to spend alot of time tuning but they should work fine. I was running #22 Multech 2's on OBD1 last year w/o problems.
What O2 MV levels were you getting and what injector PW readings were you seeing?
Or did you not go that far into tuning?
