ok, first off. in one of your old replys, you stated u can make 2 hp per litre? so your cars 6.8 hp???? i think you mean 2 hp per cid
any ways, the thought of going past 7500 rpm is odd.
for rods, if you want to go high rpm, i recommend cat power h-beams. sure there not rated to 8200, but they have been up in the 7000 range. and tere strong. also, the valvetrain can take 7000 rpm, but thats where ive failed, horribly!. but just why is it so important to get 8200 rpm redline???
another thing. that 3.1 race motor you built. theres no reason to run block filler. im making those numbers without filler. the only modification ive made to the block is girdles.
i have enough experience with these motors to know what goes on... well, not lots of experience, just boosted experience.
