My 96 beretta has a 3100 and i removed the cat and resinator. after the cat was an o2 sensor. i took it out and unplugged it for now. i was wondering if i put it back in my exhaust if it would adjust the a/f ratio wrong because there is no cat. i dont want to loose performance by putting it back in, can anyone help me out here?
96 3100 o2 2nd o2 sensor
1996 Beretta
3100 SFI TURBO
T28 60 Trim Turbo at 9psi, Stage 1 turbo cam mms, lifter upgrade springs mms, P&P heads, ls6 Valve Springs, Ported exhaust manifolds, Hyperuetectic pistons SP, 3.29 trani, MSD 8.5 wires, open exhaust, Pulstar plugs, 3400 intake manifolds, ported TB, 36 lb/hr injectors, RCI Fuel cell, Walbro 255 pump, A/C Bypass, and much more.
13.1 @ 103 mph best in the 1/4 mileTags: None
you'll get a code for low catalyst efficiency. The easiest solution I have for you is to buy this:
The largest supplier of aftermarket performance parts for 3800, Ecotec, Sonic/Cruze, and ATS vehicle platforms. We engineer unique parts in house that you won't find anywhere else!
It does work, and a good price compared to others.
Oh and to answer your question, the downstream O2 should have no effect on the engine fueling.Brian
3400 SFI V6, 4T60e
thank you much for the info that helps alot
1996 Beretta
3100 SFI TURBO
Will that work for a 96? Lists only 97+ GP's...SpudFiles
Theopia
Enjoy life online.
yeah it'll work, I've used it with a '96 PCM in my Olds. That company is L67/Grand Prix biased, so the universe didn't exist before 1997.Brian
3400 SFI V6, 4T60e
