hey, here is my question:
do you think that instead of a conventional sfi or mpfi regulator that ultilizes a return line i can basically have a line coming from my tank that goes to a regulator mounted to my firewall, then before the regulator Y off of this line which would then go to the fuel rail, and terminate (no return from the fuel rail). the return would be on the regulator itself on the firewall and be sent back to the tank this way?
is this possible? I mean the fuel rail should still see full pressure as it must pressurize this before the regulator lets fuel back through the return line.
the advantage is that i only then need to run 1 line to my fuel rail and would be less clutter. what do you guys say?
thanks
thanks
