I'm looking for stuff I could do to my LX9, I'm already planning on port&polish along with air intake and exhaust. Whats the bore of the stock throttle body and how big could I bore it out, and lastly whats the peak performance injectors I could put in it?
What can I do to a 3500?
Stock throttle is 65mm on a 3500 but its electric control, so you'll need a new TB anyways unless your car has a 3500 already stock.
Headers would be nice, or at least keep the nice exhaust manifolds and re-work them to fit. You wont need bigger injectors unless your stock ones max out, and you'll need to be able to tune your computer as just swapping in new injectors will result in flooding at idle as the computer is set for the injectors it came with. Being able to tune is key.sigpicNew 2010 project (click image)
What vehicle is the engine in?2000 Grand Am GT
2011 Chevy Impala
I doubt you need a bigger TB, the heads allready flow TONS, the exhaust manifolds are pretty damn good too... Your best bet is to put in a cam that'll use that badass top end. For exhaust, i'd run something bigger than stock, maybe 2.75" if you can find it, a good flowing muffler as well.
Originally posted by salbers88 View Post3500 is stock I need to know how much i can bore out the throttle body and intake to match, or if anyone knows of any aftermarket TB with manifold
Also, you will want to find something to reprogram the ECM for performance upgrades.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
Both DHP and HPT have yet to support the LX9, I wish one of them would step up and get support for these vehicles.
As far as performance goes, you might want to start with the exhaust. See if you can't rework the Y pipe where the exhaust manifolds connect and then do a cat back.
Then go with the ported upper and lower manifolds, flow results look amazing on these manifolds.
If you really want to get in to performance then I would go with a cam regrind. The LX9 shares the same cam as the 3400 engine, so any 3400 grind should work.2000 Grand Am GT
2011 Chevy Impala
Originally posted by salbers88 View Postis the LZ9 cast aluminum intake and heads too? and would the intake and heads bolt up with the LX9
Edit: There are some pics of the LX head gasket on a LZ head in this thread.
'79 MGB - LZ9 - T5
how bout this one?
:http://60degreev6.com/showthread.php?t=34223&page=6Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Originally posted by salbers88ok, and if i wanted to give it VVT could i just transfer heads from the LZ4 3500 on to my lx9 or is there more involved, and now did we decide the lz9 heads would fit on the lx9 or not?
I believe the LZ4 heads are the same as the LZ9 and will not fit either.
Exhaust, cam, porting and TB improvements would be your best bet at this time.Last edited by CNCguy; 02-21-2007, 12:07 AM.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
