i'm looking into building a very hi po 3400 and wanted some intoo my specs,
3400 block stock bore
3.4 dohc pistons
stock rods shot peened polished with arp bolts
crank knife eged and the whole lower end balenced
3500 heads gasket matched and cleaned up
3400 upper manifold poted with twin 58 mm throttle body on it flows 1065cfm
roller cam with roads chevy lifters
cam specs:
lobe center 114
intake centerline 112
intake duration 282
exhaust duration 286
intake lift 530
exhaust lift 550
compression should be about 11.50, custom headers with 40" primarys and 1 5/8" tube, crane rockers and custom pushrods. looking for about 350+ hp
engine will be spun about 8200 rpm max! the engine will also be megasquirted what do you guys think.
3.4 dohc pistons
cam specs:
lobe center 114
intake duration 282
intake lift 530
exhaust lift 550
