Help with injectors...
  • Help with injectors...
    Hey guys, been looking here for a while - this is my first post.
    Just finished installing some small block Ford 1.7 rockers on the firebird (3.1 LHO),some 24# blue top injectors and an Adjustable Fuel Pressur Regulator. Now idle isn't happening and running rich even with the stock FPR low as it can go. I was hoping it could be done mechanically untill I get MegaSquirt going.
    Any suggestions would be greatly appreciated.
    what pressure did you turn the injectors down to. because i don't think they are going to like being below 30psi iirc ford rates them at what, 38#?
    got zap-straps?
    89 Z24
    13.886 @ 96.16 mph
    street trim - slicks
      Haven't checked the pressure yet, got tired after the rocker install. While I was at it, painted the UIM. I turned the stock FPR down as far as it would go. And yes the Ford injectors are underrated in comparison the GM's. I'm surprised you didn't ask about the SBFord 1.7 roller rocker arms I found that work on the pushrod 60*...
      They were $69 delivered and bolted on using the stock pivot balls and locking nuts, not to mention they fit under the stocker valve covers.
      After some discussion on another site it was suggested to "gut" the factory FPR and rely on the aftermarket one.
        It's awesome that the ford rockers fit. But the question is, do they match up geometry-wise?
        1995 Grand Am SE
          They fit on a 3.1 from a Firebird, ie a iron head engine. There are alot of rocker that will fit the non-splayed valve heads. Its the aluminum heads that it is hard to find rockers that will work.
            I used to have the 24# blue tops.
            Without proper computer control, I think you're gonna have to go back to stock injectors. 24 is just too big unfortunately.
            Franz
            1990 Z24-NA 3.1L
            14.72 @ 92.24 MPH
            14.89 @ 94.92 MPH
            The boost is coming....
              u can use 24#'s but u need to drop the base fp,its not optimal but it does work,i have done it and other ppl on tgo have done it,it will run slightly rich @idle though.
              mainly his problem is he installed a afpr in the return line from the fuel rail,the stock fpr is still installed holding the fp @ 42-45 psi.also with i beilve u will see decreased vacum from the 1.7's which will also make the stock fpr increase fp slightly
                i'm already using the gold race series rockers, + as other guys said i also have aluminum heads and there's not very much space.
                i would be more concerned about the fact the only mods are the rockers, on an iron head 3.1 engine and you have 24# injectors. i'm pushing 200hp and 24# injectors are perfect for my application running 85%
                if anything i would be more inclined to go back to the 16# injectors and bump your pressure UP until you get your MS working. the other thing with dropping the base fuel pressure without knowing what it is, when you get the vac reference to drop the pressure further at idle the quality of the fuel pattern coming from the injector will be pretty poor. practically pouring fuel into the intake rather then atomizing the fuel as it is supposed to be.
                got zap-straps?
                89 Z24
                13.886 @ 96.16 mph
                  stock computer and 50% bigger injectors is not going to work. i tried running 19lb injectors on my built motor before tuning and it idled very rich, stumbled all the time. when it finaly cleared out around 4500rpm it went like a bat outa hell. it wasnt until i got my megasquirt in that i was able to use these injectors.
                    hes going turbocharged shortly,thats why he droped the injectors in the motor,while he had the manifold apart to install the rockers. im pretty sure the car isnt his daily driver
                      Hey dave! Thought I might see you here.
                      No the Firebird is one of my four vehicles, and would like to get the turbo installed soon. And yes the reason I changed injectors already is because I had the top of the motor apart. I might go back with the stock injectors just so I can go to the track on Wed. and see if there's any difference with the 1.7's
                        Gutted the stock FPR and the car idled today, but it's throwing code 33 (low vac @ MAP). To get the vacuum for the AFPR, I tee'd off the window washer and off the MAP and neither worked (to correct code).
                        Help, please?
                        BTW, could it be because of the lopy idle I'm getting since the rocker swap?
                          Why couldn't you use the vacuum from where the old fpr once connected too?
                          Yes the rockers would be more than likely giving you a slightly more lope. I know the 1.6's did for mine.
                            Did it throw a 33 code at idle? Vac at the stock location on the throttle body seemed to be low for the AFPR, but I'll try that again and get back. Thanx 1988GTU!
                              no codes.... as of yet. I do expect a failing O2 soon since it does run rich.
