Best bang for the buck would be new large port intake manifold. Since your 3100 is a 96 you should have roller rockers. If you do, then swapping on a large port lower and upper is a no brainer. If you don't then you'll have to grind the LIM to clearance like I did, or swap on new heads (3400 or 2000+ 3100 heads) which gain you a little better performance too.
Now for a direct bolt on LIM to your coolant pipe, you'll need a 96-97 (maybe 9
mini van. It's threaded for your coolant pipe. or get a newer one and tap it.
The 2000+ upper will bolt on and you can use the new style EGR with your existing wiring, but you might need the metal tube that goes to the exhaust. A 3500 upper requires a little more modification, and porting, but is even better. It has the same style EGR as 2000+. Click my avatar, then select all threads started by user, and look for 3500 swap check list I think is the title. I've got a lot of stuff in that thread detailed out for the 3500 upper.
For a direct bolt on upper, a 3400 from the same year mini-vans would work too, and your EGR goes right up to it.
So intakes or heads and intakes would be good if you dont want to pull the motor. And yes good designed headers would be cool.
Question: When you guys are saying crank horsepower, you guys aren't rating it net are you? Cause net a whole 3400 is only 185....
