I have a 96 chevy lumina with a 3100 v6 I was wondering how to get the computer in the car let me Go past 105mph I want to be able to go fast in a "granny car" so far I have a staight pipe I was thinking about taking out the cat and puting in a cherry bomb class pack but I want to go over 105mph
how to increase top speed
You should think safety before speed. Chances are you don't have performance oriented shocks/struts, sway bars, lower riding height for a lower center of gravity, sway bars, polyurethane bushings or new rubber bushings.Clean Feet Pet Clean Up
Pet Waste Removal Omaha
We offer dog waste removal and cat waste removal services.
(402) 320-3824, We service the Omaha, Ne. metropolitan area.
dont forget about speed limits.... no offense...but that car isnt hooked up enough to go over 105... nor will it ever go over 105 with out help from dhp.. and i kinda wish they didnt allow everyone to have access to the speed limiter.. youll run out of hp around 110 anyway..1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
yes even if you had a place to go this fast, that granny car is a boat and won't be very stable at high speeds, and also, it's heavy, and not very aerodynamic as say compared to an L body with suspension mods...
Not to sound like a parent or anything, but crashes suck, let alone ones past 70mph.sigpicNew 2010 project (click image)
Don't take out the cat either if that is your daily driver and not a race-only vehicle. There's no point. You gain all of 1-2hp between that and a high flow cat... big whoop. Get a high flow cat if you're looking for improvement in that area. Don't pollute!
As for the speed governor, since you have a '96 3100 you should be able to get a DHP powrtuner or HPtuners and either one of those will allow you to custom program your engine and remove the governor. Just think about where you plan to actually run that fast and the shape of the rest of your car first! Suspension like everyone else said, and don't forget about brakes! It's hard to stop from 105mph if your brakes overheat.'97 Grand Prix GT 3800 (sold)
Gotta love boost!
Originally posted by AaronGTR View PostAs for the speed governor, since you have a '96 3100 you should be able to get a DHP powrtuner or HPtuners and either one of those will allow you to custom program your engine and remove the governor.
word
94-95 was the gray ODB1.5 years. 96 was first year of ODBII.
Don't forget tires rated for the speed you want to go. Having a blow out at triple digit speeds won't be fun.sigpicNew 2010 project (click image)
Once he gets the limiter offline he can go as fast as the engine can handle. Although if "he" tunes it incorrectly well he can literally drive the engine until something goes. Also to go over 105 you'll want a new suspension depending on what you want 600-1200. H or Z rated tires 300-800. Ebiach lowering springs i think 250. Plus the DHP tuner 410 unless you have it tuned somewhere probably 100. Plus you can get sway bars i'm not sure whats out there but about 400 for 2. It depends on how those are setup. After all that feel free to do w/e you want.Last edited by Tdunk; 01-15-2007, 09:14 PM.
Originally posted by sharkey View Posti wouldnt say that. a couple guys (treez24 comes to mind) have run over 100mph in the 1/4 n/a. granted that was in a lighter car, but its still possible with an n/a motor.
querter mile
I know that I will not hit 100 in the querter I have not had a chance to take my car to corodova which is are nerest drag strip hoping to this spring I am going to run it stock to see what shes got after that I am trying to come up with good ways to make more horsepower I was thinking about planing .040in off the heads to increse compersion is this a good idea I want to make a little more horsepower with out cuting deep in to raliabilty i can get the set of heads planed and checked for $ 85
