built bottom end
  • #16
    question is how much will the stock bottom end hold? 15psi? 20psi? 25psi? 400whp? that's what i want to know and might have to find out the hard way.....
    • #17
      well on my next dyno session with the 3500 i hope to see at least 450-500 wheel.!
      • #18
        hey farmerz24 is that 3500 n/a or does it got boost ? anywayz 450-500 is very impresive
        • #19
          The most I actually dynoed was 430 to the wheels at 16 psi. I did run it as high as 19 psi (probably around 480 wheel HP) with no problems.
          The problem is always going to be traction and drivetrain, though. I busted a couple of trannies, several stock axles, several Driveshaft Shop Axles, so.
          Curtis
          91\' Turbo Z24
          http://www.turboz24.com
          • #20
            Is your bottom end stock z24?
            Clean Feet Pet Clean Up
            Pet Waste Removal Omaha
            We offer dog waste removal and cat waste removal services.
            (402) 320-3824, We service the Omaha, Ne. metropolitan area.
            • #21
              Originally posted by rickykline View Post
              i might just drop in a 3500 and throw in the forged crank if it doesnt have one in it.. then 327 rods with a nice set of 8.5:1 wisecos... anyone have the specs of the 3500 crank? and rods?
              327 rods won't work on a 3500 crank, the rod journals are different sized.
              with a 3500 crank you're stuck with the 5.7" rods for the 4.3 V6 then custom pistons will be needed...
              • #22
                thats insane lol
                your going to have to take me for a spin in that beast this summer lol
                where do you take her for the dyno and how much is it?
                • #23
                  The only "Stock" part is the block and crank. Crower forged rods, Ross racing forged pistons.
                  Curtis
                  91\' Turbo Z24
                  • #24
                    turboz24 - i don't get it 430whp and only a 12.3 1/4? what gives......
                    • #25
                      I think thats called traction issues...
                      • #26
                        Yes i know that, but IMO I would think that you turn the boost up as you do mods to gain traction......
                        • #27
                          full boogie FTW!!! who cares about traction...just get some M/T crinkle walls
                          • #28
                            Actually, the 12.31 run was only on 10 psi. I did attempt to run 16 psi for the track, but on launch, sheared the driver's side Driveshaft shop inner CV, so never got a run in.
                            Curtis
                            91\' Turbo Z24
                            • #29
                              oh damn, well at least i know the bottom end won't be the weak point then...
                              • #30
                                yeah guys I wouldn't worry about the bottom end much. Midnight is running all stock and is breaking axles.. I'd worry about transmission. I mean there is only so far you can take these cars before trans is the limiting factor...
