has anyone ever modified a 3400 upper intake to accept a lt-1 throttle body?.....i am swapping the top end off a 3400 onto my 3.4 firebird and want to upgrade the tb while i am at it....any help?and you guys have been more helpful then most of the guys on the RWD forums...they mostly say swap in a v8...lol...you actually try to help me and i thank you for it
lt-1 throttle body on a 3400?
Dual 53mm is HUGE for this engine. It will be tricky to adapt a dual-TB unit to the 3400 upper plenum. You are better off with a large single.'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
i have a friend that can weld aluminum...he does it for a living....if i can get a tb he can machine an adapter plate and weld it to the neck of the plenum.....the lt-1 tb are sold for the 3.4 rwd with modificataions to the plenum...i am doing a top end swap off a 2000 3400 onto my 3.4 firebird and a bigger throttle body will help me hit or exceed my goal of 200 to 230 rwhp
I am familiar with the LT1 TB's mounted on modded 3.4 upper intakes. The shape of the 3.4 intake makes this a lot easier. Not saying it will be impossible, but like I said, it will be tricky. The fuel rail and FPR are right where the TB will want to be.
Your welding and fabricating resources are better off adapting a large single TB for your goal. A 65mm-70mm single should be capable of supporting 220-230 whp, assuming the rest of the engine is up to the task.
The dual 53mm is pretty close in size to a single 75mm, which comes stock on LS1's, and supports well over 300whp worth of air flow. Don't waste your time trying to fit a square peg into a round hole when it doesn't gain you anything.'99 Z-28 - Weekend Driver
I've got new 75mm throttle bodies in the mall... might be buried on page 3 or something...
Probably too much for a stock 3400. I wouldn't say 300WHP, but 300 flywheel hp. They are used on 4.0's, which have 250 flywheel hp. If you're planning on modding to that power level, it's something to look into.Okay now, that's enough of that.
Was waiting for Ryan to pop in with one of his TB's...-Brad-
Originally posted by stormwolf1972 View Postso i should just use a single large tb from an lt-1 or ls-1?....and i am mounting this on a 3400 upper intake not the stupid y shaped piece of junk that came on the car...it will be headed to a scrap yard very soon
Yeah...we got that part...you are doing a 3400 top end swap..told us several times already. Take a good look at the 3400 plenum, and you will see why a large single is best. One of Ryan's is probably your best option.
I wouldn't scrap the stock 3.4 intake. It is an improvement over the earlier gen1 MPFI intakes, so you might try listing it for sale on here or the Fiero forums.'99 Z-28 - Weekend Driver
Originally posted by ryan.hess View PostI wouldn't say 300WHP, but 300 flywheel hp.'99 Z-28 - Weekend Driver
http://www.megamanual.com/v22manual/minj.htm#throttle scroll down a bit and you will see the tb size calculator. it gives you an idea on how big you need to go. keep in mind that to big causes tuning issues (makes it harder) and makes the throttle touchy
To make it an easy swap you want a throttle body from a FWD car that's pull from the front.
Edit- in the firebird you'll need an LS1 throttle body. I thought this was in a FWD carLast edited by ryan.hess; 01-05-2007, 01:48 PM.Okay now, that's enough of that.
I have someone else that wants this done (dual throttle plate). It does have its advantages for having more possible airflow at WOT but still having less air at part throttle than a single larger plate. Drivability should be easier.
Doing it is not easier though. To use an LS1 tb on a 3400, you will need to cut and weld a new flange anyway, or adapter it to stick out more and do a lot of porting. Id rather cut and weld.Ben
