I'm hoping you all can help me. I'm looking to go to a larger injector for my 3.9L G6. I won't be installing them right away, I have some other mods to finish first. It will be tuned with HPTuners when they finally go in. Does anybody happen to know of a larger injector that will work (~40 lbs)?
Bigger injectors (3900)
Originally posted by 06G6 View PostI'm hoping you all can help me. I'm looking to go to a larger injector for my 3.9L G6. I won't be installing them right away, I have some other mods to finish first. It will be tuned with HPTuners when they finally go in. Does anybody happen to know of a larger injector that will work (~40 lbs)?
Since you have access to the code perhaps you can shed some light on the VVT table for that engine.
The fuel injectors from the 3.8L will not fit, they're to long. The flow rate that I posted for the 3900 under the 3900 thread by CNCguy is at a little higher fuel pressure than the 30 lb/hr injectors I mentioned earlier are rated at so they would probably flow at about a 31 lb/hr rate or higher depending on the pressure difference, I don't recall it.
the ones you have should be good for anything that 3900 will put out all motor...
i'm using #24's on a 300+ HP 3500...
