My Crane 272 EDIT: Lifter Question also
  • My Crane 272 EDIT: Lifter Question also
    So I just bought a new Crane 272 with the Crane valve springs off ebay for a $100 http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
    Ive looked at the specs on the springs, 105# at 1.700" 296# at 1.200" and a max lift of 0.547" He says in the auction that I'll need the retainers specific to the springs, but I cant find them anywhere. Heres a link to the springs on crane's site: http://www.cranecams.com/?show=brows...rtNumber=99848 He does say that Summit has them, but I cant even find the retainers on Crane's site. I dont know if anyone has dealt with these springs, but if you have, lemme know about the retainers and locks. Im going to assume I would use stock shims. TIA
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    I dont know what springs you have that require special retainers. I run a 272 cam and z-28 Springs up to .520 lift that have the proper seat pressure for the 272 cam. You can buy these springs for under $25.
    What is the diameter of these springs you bought????/
    1992 Chevrolet S10
    2.8 v6 tbi 5 speed
      The outer diameter of them is 1.255. And the innter is .870. Its a single spring with a damper. Check out the link in my first post. Im just quoting what the guy said in the auction. Im wondering if its true or not
      Robby Whitesell
      2006 Pontiac G6 GT
        You need different retainers because of the install height. The GM crate motor retainers will work for you.
        When it's time to schedule maintenance or you need vehicle repair services, turn to the vehicle care experts at GM Certified Service. View available services today.
        P/N 12363216
          P/N 12363216
          Yeah, checking out the springs those retainers are made for, those are the ones. Thanks man, I appreciate it. I didnt realize the Crane springs were same as the GMPP 3.4 springs.
          Robby Whitesell
          2006 Pontiac G6 GT
            Um I think they have slightly different seat and open specs.. But cannot remember. I am using the retainer on my truck and I was very impressed with them. They are quite heavy duty.
              Gm retainer 12363216 will work as betterthanyou has said. Crane also have a retainer that will work with the 99848 spring. Unfortunately Crane have redone their web-site and there isn't quite enough info remaining on retainers, so you will have to call them to get a part numer.
              The important thing is to use a retainer and/or keeper combination that lets you set the installed height of the spring at 1.7"
              \'83 S10, 3.4 SFI, 4L60E
                Yeah, thats what I was thinking. I just couldnt find any info on crane's site because of thier redesign. So, I got the retainers picked out, shouldnt stock keepers from a 3.1L work?
                Robby Whitesell
                2006 Pontiac G6 GT
                  Alright, heres the lifter question: I think its a good idea to get the Crane lifters with the 272. Anyone know if stock are just as good? Either way, I'm getting new ones. I just wondering if its worth the $$$ to get the Crane lifters
                  Robby Whitesell
                  2006 Pontiac G6 GT
                    Um Cranes are probably the same. I've never had a problem with GM lifters.
                    Yes your stock valve stem locks will work with the GM retainers.
                      Thanks!
                      Robby Whitesell
                      2006 Pontiac G6 GT
