So in my quest for building a better cylinder head I have been doing some research and think that this may work I haven't ordered the valves yet Cuss I'm talking to my neighbor about it (He owns a Cylinder head shop)
But the pre data would indicate that you can change to larger valves with out having a custom order..... Nice
Stock Valves are as follows.
1.720" head 4.73 +/- .005 Over all length .3415+/-.005 Stem Diam .100+/-.005 Valve seat width .050 margin and last .270 On the tip length
1.420" head 4.375 +/- .005 Over all length .3415+/-.005 Stem Diam .200+/-.005 Valve Seat width .070 margin and last .300 On tip length
And the nice non custom performance upgrades are From the Buick v6
1.500" .3415 stem diam 4.725 Over all length .270 Tip length (30° x 7/16" Back cuts or under head) .075 margin .090 valve seat width 20° Dish 98 grams
1.710 .3415 stem diam 4.730 Over all length .270 Tip length (Pro Flo: 12° x 3/8" Back cuts or under head) .065 margin .080 Valve seat width 7° Dish 95 grams
What’s this mean you loose .010 on the intake not as important as getting rid of the exhaust which you will gain .080 and still leave .070 between valve margins.
Also the intake I should point out is a pro flo so that means the stem diam is reduced coming out of the valve guide increasing flow.
The last is you may have to change out retainers but who gives a crap about that.
These are Manley Valves and should work. From all my calcs yes the exhaust is a .010 shorter but you know what the seat lock is moved up so there isn't any problem with coil bind and would be good to the same valve lifts if not more than the stockers...
I hope this benefits you guys as I know it will me.
