Question about M90 intake manifolds
  • bjornmk1
    replied
    and how about the drive belt?
    would that be a 6 or 8 groove serpentine..cause if you go the 8 route
    then you would have to change all your pulleys.
    personally I would go the 8 route for less slipage.
    unless it's only gonna make about 8psi or so...then the 6 should be sufficient.
    just my 2 cents.
    bjorn
    replied
    +.060" bore will make them fit.
  • TazMan
    replied
    Yeah, swap the 3500 top end on it:P Thats the best route to go anyway.
    I thought I read in a post somewhere that the 3500 heads could only be swapped to a 3400 cause the combustion chamber was to big for a 3.1/3100 or something like that? Did I misunderstand/misread something?
  • PCGUY112887
    replied
    SC's are cool but it seems that a turbo project would be easier/cheaper/no hood issues/possibility for more power without changing much?
    From a business standpoint, it seems like a set of great priced turbo headers would sell the most. Or hell even selling modified stockers that have been cleaned up/sprayed with your flange of choice could work. Offer some pre-bent IC tubing for a small IC that is made to fit in our engine bays, would be great.
  • CNCguy
    replied
    Originally posted by silvergtjrad View Post
    Has any attempt or progress been made on this yet? Just a way to mount the charger on the manifold so that it lines up with the accessory pullies. I would be willing to front some $$ assuming that it could be created in a reasonable amount of time.
    Done a little bit of the CAD work but nothing yet on machining. Been way too busy to work on it. It is not my highest priority project at this time. Several others still in front of it. I will update everyone when I make some progress.
  • stormwolf1972
    replied
    oh yeah it will sell....hopefully it wont be too long length wise......dont forget us 60 degree f-body guys....that damn cowl...grrrr.......but keep us posted...i was thinking about a 4 inch rise ram air hood anyway...this would be a good excuse to get it
  • silvergtjrad
    replied
  • turboghia
    replied
    I would be willing to buy that.
  • blackbombshell95
    replied
    This would defiantly sell
  • barrok69
    replied
    Interested, keep us posted with progress!
  • Daguse5853Z
    replied
    I think this would definately sell! I'm interested in the kit and to see how it all turns out.
  • gopedxr7
    replied
    i would be interested. just in a few years, dont have the money right now, i am still in college.
    from what i hear the options for my 2004 monte carlo 3.4 for supercharging is pretty limited to one unit and from what i hear it poor quality and overrides alot of engine functions to make it work. which i am not too happy with
    Alan
  • EspanolaGuitarista
    replied
    Does anyone have the specifics...
    ....I would like to run the supercharger through my engine pro. I need belt ratio, Island CFM, and compressor map if possible. It would make around 250-260 without a problem.
  • CNCguy
    replied
    So from what I see, you'll be flippin the SC upside down? The out let on the bottom?
    Correct... from what I've read, Eaton says it can be rotated any angle. The only problem is the oil fill plug is upside down. I believe that can be resolved by adding an extra filler plug in the cover.
  • Guest
    Guest replied
