I am assuming that you plan to have these manifolds cast correct?
Also I am not sure if the super coupe used a bypass valve, but I would highly recommend using one for this setup. http://www.magnusonproducts.com/bypass.htm
Also, a few other cheap eaton superchargers are as follows
M90 from the GM 3800 engines (down side is that the way it mounts might be too wide for the 60*v6 heads.
M62 from a nissan frontier/xtera very cheap and easy to find. If you are interested I can take measurements as I have on in the garage.
Or the M112 from a Ford mustang or lightening pickup would be awesome, they are currently running around $350 - $500
