Hi there!
For this design, you would use a knock sensor (not the same one you've got, an additional one) and an ESC module. The ECM is not connected to it in any way. The signal that would normally go to from the ESC module to the ECM is what will drive your injection system. You'll also need to hook up power and ground to it.
ESC module:
Pin A -- unused
Pin B -- 12V
Pin C -- "Knock" signal to your injection system
Pin D -- Ground
Pin E -- wire connected to the knock sensor
You don't want to build anything that tries to use just the knock sensor without the ESC module, since anything you build would have to duplicate the circuitry in the ESC module. That module is essentially a bandpass filter tuned to the same frequency as detonation in your engine. It has some additional circuitry to set the state of pin C (powered or grounded) based on whether it detects knock.
So, you'll connect it as described above, and pin C would be the input to any power-switching circuit you have to run the pump. No ECM required.
ESC module:
Pin A -- unused
Pin B -- 12V
Pin D -- Ground
