3500 Heads
  • 3500 Heads
    Ok so i have heard alot of diff things, and im tryin to figure it out...need some help. What would the compression ratio be on a 3400 with the 3500 top end swap, heads being stock height and deck normal also. And also are the 3500 heads any taller physically that would warrant custom length pushrods?
    9:1 vs 9.6:1 compression using stock 3500 heads and valves. Same length pushrods and rocker arms but smaller bolts for the rockers form all 03+ 60V6 pushrods and the older 10mm studs.
      ok, so have u heard anything back from anyone that has used the gold race rockers u have on the store, or can they be used on the 3400 with the stock valve covers
        Yes, they can be used with stock valve covers. There are several members on the site that currently are running them. Do a search and you will find countless threads on them.
