Ok, here is the rundown... The car is a '88 Buick Regal w/ 2.8 6Mos. ago the previous owner went to replace the lower intake gasket due to massive loss of oil
Upon reassembly, the car won't start. Now, this guy was like "give me a distributor and points, and I can make it start". Basically he had the wires backwards, even bank on odds and odds on even. After switching them back still won't start. He gave up on the car and gave it to me. Since then I have:
-checked fuel pressure (it checked fine)
-had the coils and the ign. module checked (checked fine)
-made sure everything was hooked up properly, including under the upper intake w/ the injectors (everything is hooked up and fine)
-checked grounds (all fine)
-checked injectors (all checked within range)
-checked spark (its there)
So.. now I'm here asking beacuse maybe there is something I haven't thought of. One thing: it was massively flooded when I got her. So bad that the oil has gas in it. I have tried pulling the plugs and drying them (always wet they are), and same result. When turning over, the engine is "trying" to fire. Once in a while I get a pop or two. I wonder, could it be just that terribly flooded?! Hopefully you guys have a better inkling for me! TIA!
Mike
3400 Beretta Z26
2.8 Buick Regal
Mike
3400 Beretta Z26
2.8 Buick Regal
