Originally posted by ckrobins
View Post
I don't have experience with a Grand Am but have pulled the TC cover off of other 60V6s with the engine still in.
I would not go by the marks on the dampner, there are marks on your timing gears that you align to get the timing correct. The marks should point towards each other as shown below. As long as the marks are correct, the timing should be right. Sometimes the crank gear mark can be hard to find but if you pay attention to the keyway location, it will give you an idea where to look for the mark.
It is an interference engine.
