okay im not sure if maintenance is the right heading but here goes.
i installed a 3.1v6 aluminum head into my fiero. i am running stock fiero computer with a distributer. this was for ease of install. i have injectors from a 3.4 TDC. I am running a K26 turbo off a porsche with a turbonetics 35mm wastegate. i also have a fmu. i had some chips burned for me to compinsate for the injectors at idle and a 2bar map sensor. i am still in the working out the bugs stage but my motor struggles to rev past 4000 rmp's and runs extreamly rich on idle it also does not build boost. it drove fine before with injectors and fmu it was just rich at idle and slightly lean in boost. im lost and don't want to just go throwing money and things that don't cause this problem. my ideas so far are spark issue, exhaust blockage out of turbo, bad intake gaskets/hudge vac. leak. any ideas would help thanks.
