ok, i'm having to replace my lim gasket, and i'm about to remove the im and the last thing attached is what looks like a big (1") plug screwed into the back driver's side corner of the im with a coolant line coming out of it that runs up to a metal line that goes through the firewall. from looking at sensor location pics, this looks like where the coolant temp sender should go. when i tried to unscrew it, it broke off (without too much torque i might add) and left what looks like it's aluminum nipple stuck in the hole in the intake manifold.
i have the BASE instrument panel.
is this the coolant temp switch? what's throwing me is that there arent any wires coming from it. there's just an arrow indicating the direction of flow embossed in the metal on the thing.
i have a GUAGES panel coming from ebay. if this is indeed the coolant temp switch, is this what i'm supposed to replace with a coolant temp sender anyway?
i've been trying to find a pic of this, but all i ever see are the senders.
