Okay guys, I am at the end of my rope..
..My 94 Cutlass Supreme won't start..
Heres the story:
Last week, I was out and about, running around town and so forth, and the car was running fine.. No problms with it at all.. I got to my final destination to work on the Lumina project, and I was there for 3-5 hours.. I hopped back in the olds to head home, and I started it.. It foired just fine, but I put in reverse, and went to accelerate backward out the driveway.. The car stalled out on me right in the middle of the street.. I could start it subsequent times after but it would idle very rough and eventually die out.. It has been sitting there ever since..
..It will crank and crank just fine, and I have spark coming from it (I hooked a plug to a wire, and I can hear it sparking in a regular pattern..) I changed the fuel filter just becasue it probably needed it, but now it is leaking gas out of the rusted ass fitting that hooks into the filter.. Here is a list of what i have changed on it:
I have changed the coils
Changed the ICM
CHanged Fuel Filter
I was going to try an idle relearn, however it wont stay running long enough for me to do that.. The idle relearn takes I believe 15-20 mins, and I am luck to get 45 seconds of idle out of it..
I am getting spark, and i can hear the fuel pump kick in.. But, here's something I noted: I don't hear it when I first turn the key.. I only hear it after I try cranking it and it does nothing.. What else could my problem be? Any help you all can give me would be much appreciated.. I really need my car back.. Thanks..
Heres the story:
Changed the ICM
CHanged Fuel Filter
