topic, does anyone know how to do this? (and please dont just tell me to get a haynes manual, im going to get one soon enough but i would figure that there is some way i can do this before then...) thanks guys.
how to check & adjust cam timing-92 firebird 3.1
remove accesories
remove water pump
remove the damper/crank pulley
remove timing cover
turn the crank till #1 is tdc
check that the marks on the sprockets align face to face ( like ><)OR the cam sprocket can be up and the crank can be up as well (>>)If you aren't friends with a liar, you aren't friends with anyone.
