I've personally never been this deep down into a 3100 motor, so dont mind the retarded questions.
when i plan to do this i also plan to change to a gaterback belt, new plugs AGAIN, new 180 degree thermostat and sensor. I'm also adding a low coolent sensor since my damn light keeps staying on.
My question tho is when i change the lower intake gasket would i need to change the upper intake gasket as well? or anything else i should order. and if so can you please provide part numbers.
The part #s i've found so far is this one.
V6, Upper 12480824
V6, Lower 12480829
V6, Upper 12480824
V6, Lower 12480829
