my father in law has an o1 pontiac montana, and it has a high idle problem, it willl idle between 1500 and 300rpm, but only when the van is moving, when you stop it slowly returns to normal. I know it is not a vacuum leak of some sort because on occasion it will idle normal, if it were vacuum it would be consistant and the high idle only happens when the vehicle is in motion (let off the accelerator and put it in neutral and the idle is between 1500 and 3000) I have removed the line from the cruise, replaced all the sensors (tps, maf ect.) replaced the tb with a salvage one from a ga gt, cleaned the iac, reprogrammed and then replaced and reflashed two pcms, (both flashed with dhp 1.0) and I even replaced the bcm. I have run out of ideas, it throws no codes and gm mechanics say they can find no problems.
Does anyone have any Ideas???
