I am a new member. This site is GREAT. I want to double check that I have everything before I begin this undertaking.
2000 Olds Alero 3.4L LA1 Type "E" 47,000 mi. that is leaking coolant.
Intake gasket set - Still not certain from the posts which is preferred. The Fel-Pro MS98003T or the GM set.
195 degree thermostat - might as well replace while engine is open.
Oil pump drive "O" ring
Intake manifold bolts - long and short. Some posts said replace, others said using old ones was OK.
Have I left out anything other than new cuss words and lots of "band-aids"?
