Ok my wife has a 1995 grand prix, auto trans, 173,000 miles. It is leaking and using probably 1-2 quarts of rotella 15/40 in 3000 miles (oil has been faithfully changed every 3000 from new). It has a coolant leak on drivers side, steams like a beeatch when you first drive it, then slow down to pull in a parking lot(the decel makes the coolant dribble on the exhust is my guess), very little leakage as the level barely goes down. I know from reading here so far I need to change the Lower intake gaskets, there are some engine oil leaks further down on the engine too because I see it when I do oil change. I'm considering options, option A is to just to the lower intake gaskets IN the car, Option B is to pull the engine, and maybe trans, replace all engine oil seals and gaskets. Option C is to pull the engine and trans, go thru the whole engine, re-bearing, re-ring (bore if needed) go thru the heads and do what needs done, and maybe have the trans gone thru as well (Know a guy that does them for 200ish).
Also I see on the lower intake gasket change post the author says you will get some coolant into oil when doing the engine with a wet water jacket, I'm wondering if it would be better for the engine to flush coolant so all that is in the wj when you teardown is H2O ??
The wife had the car serviced at the dealer for the first 100k or so, so on the trans she is going to dig and see if the fluid/filter has EVER been changed.....this is a decent running car, GREAT running car in fact, and it has had struts all around once, and front ball joints...really I think it is best to keep it and just freshen it up mechanically......I'm putting in place a rigorous PM program for my vehicles, had the engine toast in my 1991 S10 and leave us with 1 car from 3 for 2 drivers, aint gonna happen again, it's going to be a brave new world in the garage from now on and only minor repairs are going to come to ME, we're gonna get pro-active :-) and fix things before they break from now on.
Bill
Bill
