Hello,
I'm doing an intake manifold gasket on a friends 97 Cutlass Supreme, initially I thought that problem was the head gasket but then I found out about the LIM problem on these motors. I was wondering though, are headgaskets something that fails routinely on these motors?
The intake manifold has been removed already so I can't do a compression test, he had started working on it already and said that the car was never down on power but just kept loosing coolant. Are there any tell tale signs these motors will exhibit when the headgasket is the culprit as opposed to the LIM?
BTW I inspected the LIM and found two obvious cracks in it, so I figure it's the LIM but for Peace of mind I figured I'd try to get some insight into this motor and this problem. One more thing, I'm used to OHC motors and the only other valve adjustment I've done has been on a 350 with aftermarket roller tip rockers. Any info on what would be the best way to adjust the valves on this thing, I was pretty surprised at how different the valvetrain was a opposed to a 350. Thanks all!
Regards,
Tee
Regards,
Tee
