help me get better mileage from this beat ass 3.1.... This car has been sitting for the last three years. it died from a bad fuel pump and I replaced it with a used one with a new fuel sock. never drove it afterwards because it was spewing fuel vapor out the tail pipe.
some info
1990 6000 SE AWD 3.1 auto
*109k miles
*100 miles and 11.8 gallons of gas
*code 33 I believe is low map voltage or something
*intake has a vac leak
*new plugs stock delcos
*new wires $20 autozone jobbers
*misc new sensors
*slightly used new cat
*runs bad (stumbling/rich) on trips to the store/when its started when warm for 30 secs then good idle returns
*coil packs/ign module i believe are fine it doesnt run bad except for initial warm startup.
*hesitates when warm on stop light take offs dies intermittently, starts back up and runs perfect.
I'm gonna change the intake gasket tomorrow, and I ordered some taylor wires to replace the cheapy autozone wires. One thing I havent touched yet is the EGR. Its oddly the old vacuum style egr like normally is on pre 88 MP's. I might try and replace that and try and patch up any other vacuum leaks. I also think i need to change the fuel filter I'm not sure when that was done last.
If anyone has any words of advice please help. I can't stand the way the car smells and I really dont think its safe to drive because of carbon monoxide.
some info
*109k miles
*misc new sensors
