If the fans are cycling on and off, then I would look into replacing the sensor. The temp sensor in the rear head is only for the guage, so it doesn't affect how the car operates. The one at the thermostat housing should be the one of concern. And if the fans are cycling, then the temp seen by the ECM is fine and the engine isn't overheating.
Corsica 3.1L - Overheating
Originally posted by bszopiIf the fans are cycling on and off, then I would look into replacing the sensor. The temp sensor in the rear head is only for the guage, so it doesn't affect how the car operates. The one at the thermostat housing should be the one of concern. And if the fans are cycling, then the temp seen by the ECM is fine and the engine isn't overheating.
This is for a 3100, but it should be about the same:
Each Coolant Fan is turned on and off by a separate Coolant Fan Relay. The Primary Coolant Fan Relay coil is grounded by the Powertrain Control Module (PCM) when vehicle speed is less than a speed determined by the PCM and the Engine coolant reaches 1O8°C (227°F) with A/C off or 1O6°C (223°F) with A/C on. The relay contacts close and voltage is applied through the Primary Coolant Fan Relay to the Primary Coolant Fan. The Primary Coolant Fan runs until the Ignition Switch is turned "OFF," or Engine coolant temperature decreases to 1O4°C (22O°F) with A/C off, or 1O2°C (216°F) with A/C on.
The Pusher Coolant Fan Relay coil is grounded by the PCM when the Engine coolant temperature reaches 118°C (245°F). The relay contacts close and voltage is applied to the Pusher Coolant Fan. The fan then runs at high speed and will continue to run at high speed with the Ignition in "RUN" until the Engine coolant temperature lowers to 114°C (238°F).-Brad-
Not sure, as mentioned, I will do a pressure check and if all is fine, I will replace the sensor on the head which sends signal to the dash guage.
Also, as part of the pressure check, I am going to remove each plug and check for signs of coolant leak in the cylinders.
I will post my finds.
The corsica is not a bad car. The most problematic things are exterior door handles changed allfour and passengers side twice. As well as an ongoing heater issue. Little or no air flow. The 3.1 is a very reliable engine. Mine's a '93. They were made from 1986-1996 the only changes to the appearance was an updated interior and dash in 1991. Be glad you did'nt buy one with one of those 2.2L four bangers.
Have you checked your water pump? It may be getting ready to take a crap.1985 GMC S-15 2.8L V6 Auto
3\"body lift 2\"Suspension lift
console shift
delta tool box
My toy
1993 Chevrolet Corsica 3.1MPFI 3spAuto
If it wasn\'t for the engine it\'d be long gone
Originally posted by 854x4s15The corsica is not a bad car. The most problematic things are exterior door handles changed allfour and passengers side twice. As well as an ongoing heater issue. Little or no air flow. The 3.1 is a very reliable engine. Mine's a '93. They were made from 1986-1996 the only changes to the appearance was an updated interior and dash in 1991. Be glad you did'nt buy one with one of those 2.2L four bangers.
Sorry to offlink, but hey
Recently, I have been getting several PMs as well as seeing many posts on the board about the temp gauge going up to 3/4s on people's Corsica V6s. This IS completely normal as long as the fan turns on around 3/4s and brings the gauge back down somewhere between 1/2 and 3/4s. On most cars this is dangerous, but NOT on Corsica V6s. Once again it is completely normal as long as no idoit lights come on. If a idoit light does come on (which all Corsica V6s have) then the vehicle is overheating or another problem could be occuring. The most common problem is the fan relay, an easy fix. The way to check to see if the fan is working is to turn on the A/C. The fan should come on when the A/C is on, or when vehicle is in diagnostic mode.
This whole discussion has been discussed already, more or lessEnjoy
Also,Originally posted by 854x4s15They were made from 1986-1996
water pump check
Thanks. How do I check the water pump? It doesn't make any sounds which would indicate a bearing issue and of course I have no coolant leaks. How I check if its flowing enough coolant?
-start engine
-let the engine warm up to where you feel the upper hose is warming up(or maybe till temp gauge is sitting past where its suposed to)
-then grab the lower hose and feel for surging
That surging is the pump working.
~Will
RE: water pump check
The sensor in the head is an engine temp sender, the sensor in the t-stat housing is the coolant temp sender. If the gauge hits red you are overheating. The gauge pulls its referance from the t-stat located sender not the head, that is where the ECM pulls its referance. Typically a T-stat will start to open at 195 degrees, fully open may be close to 215 degrees or slightly higher. Fans will turn on at about 220ish degrees. This allows the coolant to pool heat in the radiator then kick the fans, allowing for a more linear cooling.
If you are worried about it then get a different t-stat. If your water pump is not working you will know it, the engine will more than just over heat. Water pump tend to squeel really bad just before they go bad, they will work fine upto the point of breaking the shaft, there is no in between either it works or it is broke.I am back
Mechanical/Service Technican
