Starter Relay?
  • Starter Relay?
    I was at the race track with my local car club doing bracket racing tonight. And i go through all 4 test runs and dial in my time. When I go to stage in the lanes my car wouldn't start. WTF. i phuked with the wires for 5 minutes and it started. YAY. then when i went to stage, i turned off teh car so it wouldn't get hot, and it wouldn't start. holy hell. And it never started again for the whole night. And it was the last Car club challenge race of the year. And it was DOUBLE POINTS!!.
    Well luckily i had my volt meter with me. And I noticed the little purple wire that goes to the starter(14gauge or sumthin small) wasn't getting any voltage with the ignition on. So i used a screw driver to get the car started. And jumped the starter. So there is an open somewhere in that wire. And that wire goes from teh starter to the ignition. So the problem could be anywhere along the wire. When I get a chance tomorrow i will check for continunity.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    RE: Starter Relay?
    Did you check the ignition switch.
    Starter solenoid< is this what you mean..
    I am back
    Mechanical/Service Technican
