This post is generic to all engines, but I didn't know where to park it. It is maintenance related (or lack thereof).
I have a 3.4 crate motor in a small hot rod. I just dicked around for three days on and off trying to diagnose a charging problem. On Tuesday I first noticed that I had no amps and low (~12) volts instead of the usual 30 amps and 13.8 volts. Once in a while when I was checking and testing, all of a sudden I'd get charging volts/amps. Then it would quit charging again.
After thrashing through all sorts of wiring checks and trying a new alternator, tonight I was leaning toward thinking the battery (Die Hard Gold) was bad, although it cranks great, and a battery charger will juice it. Then I realized (duh) that in the five years I've had this car on the road, I had never added any water to it. (It's in the trunk - hard to get to and easy to forget about.)
Each cell took about 4 oz. of water, and as soon as I started it up, it was charging again. Don't know if it will last, but it looks like progress.
Question - does it make sense that not having enough electrolyte in the battery would cause a charging problem like this, and topping it off has brought it back? I stink at electrical problem solving and I'd appreciate any insight.
Thanks
Thanks
