I've got a 1996 olds Achieva, with the 3100 v6. It's running rich, gets bad gas mileage, and smokes black. It idles rough, but smooths out above idle. I've pulled the plugs, and they're all sooted real good. The fuel pressure is ok, and the pressure regulator is working right. I had Advance Autoparts plug their code reader in and check the codes. I get three codes: oxygen sensor voltage low on bank number 1 (do these have more than one oxygen sensor?), EGR valve pintle position, and a code for random misfire.
any suggestions?
any suggestions?
