A while ago...I had an issue with the alternator wires being pinched between the block and the power steering pump. They were shorting and causing charging problems. I have since patched up any severed wires, and covered them with a good sized helping of Electrical tape. I also bought a new battery then too.
Yesterday, I was driving around all day...no problems. I did an oil change (I did it), washed the car, watched a movie then went for a long drive. After the car was parked for a bit I went to go move into another spot and I noticed my volts gauge at around 10-11V. The signals would blink very slowly. I drove home (30mins) and the volts gauge didn't move unless I hit the brakes or used my signals. I checked all of the previous severed connections, and tried moving some of the wires to see if the Volts would move but no dice.
So I removed my starter...cleaned all the connections, and checked the fusible links.
I got a Volt meter thingy. Put one of the probes in the wire to one side of the fusible link, and another to the starter connector on the other side of the fusible link.
*BEEP* Continuity.
I tried it with all 3 FUsible links by the starter and got continuity.
I made sure the starter connections were clean and tight...attached starter and gave her a crank. It started up fine...the car was getting the exact same Volts. 11-12V
We checked the amount of power coming off the battery. 12.5V Off the Alt while running...the same. Rev the motor...volts drop a bit.
All of the wires going to the Alt have good continuity as far as I can reach.
So...again. I've tried 4 Alternators ( 1 new, and one off a car that it worked on for sure) All the Alts gave off the Exact same Output.
I've tried 3 Batteries...all hold the same charge.
I've tried 2 starters. No dice.
Any suggestions would be great. I've been bumming rides to work...the car won't hold any charge.
*BEEP* Continuity.
