I am overhauling a 3100 M. New pistons and bearings are all in and speced
I thought I had engine ready to go until I attempted to get the cam in. It sticks out the front about .125" so I have a problem. The rear plug is in with the cup toward the engine like a normal freeze plug would be, I can see a circle on the cap where the rear of the cam is hitting.
I do not see this working because if I push it back to make the additional clearance needed it will fall out. I do not recall if it was in cup-in or cup- out, appears to me it should be installed cup out.
Anyone got the rear of a block in view or remember how the plug goes, or is it supposed to be a very thin plug. Appears the machine shop used a normal freeze plug.
Also does anyone know if there is a FELPRO gasket set that includes the O-rings for the oil level sensor and other sensors. Or better yet, a list of what is included in the felpro gasket sets. I realize there is a label on the package, but no one around here stocks the gasket set, all special order. I already checked GM they only sell individual gaskets and some of the sensors are only sold as a unit which includes the sensor anf the O-ring. DUMB!
This engine overhaul is becomming EXPENSIVE!
![Surprised](https://www.60degreev6.com/vb5/core/images/smilies/icon_surprised.gif)
