I was pointed here from another web board.
`94 grand am se , 3.1L V6
It drives fine untill its warm, but once it's warm it stumbles all over itself. Driving along/accelerating/whatever, if you have your foot on the gas, it will cut out for 5 or six seconds then kick back in again. Sometimes it only cuts out for a few seconds, but does it a few times in a row so it gets all jerky. It's stalled a half dozen times now after doing it, but doesn't stall all the time.
Repaced the coolant temperature sensor yesterday, no luck. Replaced the plugs and wires (one wire was broken, one plug was cracked) this morning. Not much luck either, it's still doing it, just not as much.
I have no idea what's causing this. The only thing the computer pulled up was an O2 sensor code, but i'm guessing it's an old code since the sensor was replaced a few weeks ago.
Thanks for any help you can give me
